Group: DynoMotion Message: 5172 From: michaelthomasn Date: 6/9/2012
Subject: Disable Amp on Kmotioncnc stop
I get a bit of drift on my analog machine if I disable an axis since the amp still remains on as talked about previously.
I solved this in my Init.c with a watchdog that turns off the amp when the hardware estop is pressed. I'll have to add something for tripping a limit as well, which i think i can manage OK.
I don't understand how I can turn off the amp when I hit the stop button in Kmotion cnc, though. It disables the axis', then they begin their drift since the amp is still on.
Do i change the watchdog to check if the axis' are enabled or not?
Can someone shed some light on that, please?
Mike
Group: DynoMotion Message: 5173 From: michaelthomasn Date: 6/9/2012
Subject: Re: Disable Amp on Kmotioncnc stop
I think I answered my own question.
Thanks again.
--- In DynoMotion@yahoogroups.com, "michaelthomasn" <michaelniksch@...> wrote:
> Thanks,
> Mike
Group: DynoMotion Message: 5174 From: Michael Rosenfield Date: 6/10/2012
You can adjust the zero offset on your amp, as well. I had to do that on one of my 4 axes.
Michael Rosenfield
Group: DynoMotion Message: 5175 From: michaelthomasn Date: 6/10/2012
I actually did that, but it did not remain perfectly still. It doesn't move much, but I don't want it to move at all. I'm pretty sure I worked it out.....I'll know for sure tomorrow.
Mike
--- In DynoMotion@yahoogroups.com, Michael Rosenfield <mrosenfield@...> wrote:
> You can adjust the zero offset on your amp, as well. I had to do that on one of my 4 axes. Michael Rosenfield
> From: michaelniksch@...
> Date: Sat, 9 Jun 2012 23:19:27 +0000
> Subject: [DynoMotion] Disable Amp on Kmotioncnc stop
> Thanks,
> Mike
Group: DynoMotion Message: 5176 From: TK Date: 6/10/2012
Hi Mike,
As you alluded to you can monitor the Axis Enables and if any become disabled then disable the amplifiers.
Mike
> Thanks,
> Mike
Group: DynoMotion Message: 5177 From: Michael Niksch Date: 6/10/2012
Yes..... I am going to do that in the morning.
On Jun 10, 2012, at 6:24 PM, TK <tk@...> wrote:
Hi Mike,
Mike
> Thanks,
> Mike
Group: DynoMotion Message: 5187 From: michaelthomasn Date: 6/11/2012
Hello, Tom
So I added an enable watchdog at the end of my program. It seems to function as it should when I manually disable an axis in the axis screen. It does not work in Kmotion cnc when I hit the stop button, though. The if seems to work, as my amp and hydraulic are turned on when I hit INIT.....but it doesn't make it to the else in Kmotion cnc.
I am attaching my Init.c here http://tech.groups.yahoo.com/group/DynoMotion/files/michaelthomas/
I cannot seem to figure out what the blue axis dro's signify, and wonder if it somehow related.
I thought the dro's would turn green, but they never do.
Mike
> Thanks
> > Hi Mike,
> >> Thanks,
> >> Mike
> >> --- In DynoMotion@yahoogroups.com, Michael Rosenfield <mrosenfield@> wrote:
> >> > Thanks,
> >> > Mike
Group: DynoMotion Message: 5190 From: michaelthomasn Date: 6/11/2012
Forgive me if this is a double post....I thought I hit the send button, but I don't see it here.
Does anyone have any idea what I'm doing wrong here?
> Hello, Tom
> Mike
> > Thanks
> > On Jun 10, 2012, at 6:24 PM, TK <tk@> wrote:
> > > Hi Mike,
> > > Regards
> > >> Thanks,
> > >> Mike
> > >> > Thanks,
> > >> > Mike
Group: DynoMotion Message: 5191 From: michaelthomasn Date: 6/11/2012
Anybody have any input on this?
I 'm sure I've done something dumb, but I can't figure it out....lol.
Mike
> Thanks,
> Mike
Group: DynoMotion Message: 5192 From: Tom Kerekes Date: 6/11/2012
Hi Mike,
Sorry I hadn't realized that STOP in KMotionCNC kills all User Threads and then disables all the Axes.  So your C program never has a chance to disable the amplifiers before it is killed.
Here is a patched version that only kills all other Threads except #1.
Copy it to the C:\KMotion429\KMotion\Release directory and see if it solves your problem.
You must run your Init.c and watchdog program in Thread #1 for it to continue to run after an EStop.
Group: DynoMotion Message: 5193 From: michaelthomasn Date: 6/11/2012
Thanks Tom,
I will try that in the morning.
I was certain I had done something dumb in the c program, but I could not figure it out....lol.
Is there a more conventional way to do what I am trying to do?
Oh, and what does a blue colored dro mean?
Mike
> Hi Mike,
> http://dynomotion.com/Software/Patch/NoKillThread1/KMotionCNC.exe
> From: michaelthomasn <michaelniksch@...>
> Sent: Monday, June 11, 2012 12:02 PM
> Subject: [DynoMotion] Re: Disable Amp on Kmotioncnc stop
> Hello, Tom
> Mike
> > Thanks
> > > Hi Mike,
> > > Regards
> > >> Thanks,
> > >> Mike
> > >> > Thanks,
> > >> > Mike
Group: DynoMotion Message: 5194 From: Tom Kerekes Date: 6/11/2012
Hi Mike,
No I can't think of a better way.
The Blue DROs indicate you have the option set to display Measured Encoder Position rather than Commanded Theoretical Position.
See:
Group: DynoMotion Message: 5195 From: michaelthomasn Date: 6/11/2012
Ah.....I see.
Thanks again.
You really do provide exceptional customer service, Tom.
It's very much appreciated.
Mike
> Hi Mike,
> See:
> http://www.dynomotion.com/Help/KMotionCNC/ToolSetupScreenTP.htm#Step_Increments
> Sent: Monday, June 11, 2012 5:19 PM
> Thanks Tom,
> Mike
> > Hi Mike,
> > From: michaelthomasn <michaelniksch@>
> > Hello, Tom
> > Mike
> > > Thanks
> > > > Hi Mike,
> > > > Regards
> > > > TK
> > > >> Thanks,
> > > >> Mike
> > > >> > Thanks,
> > > >> > Mike
Group: DynoMotion Message: 5197 From: michaelthomasn Date: 6/12/2012
Everything is working great, now.
I was able to get soft limits to work as well.
Mike
> Thanks,
> Mike
